Activity Forums Apple Final Cut Pro Legacy Export as H.264 – Why the Different Quality?
  • Export as H.264 – Why the Different Quality?
    Posted by Matt Capocci on August 3, 2007 at 5:45 pm
    I know this is old news, but I still never found a good answer. Everytime I export as with H.264, my video always looks Brighter, washed-out, and the colors are sometimes misinterpreted. When you watch it on a PC it’s even worse (which I’m aware of the gamma issues between PC and MAC), but that’s no excuse for a MAC to make it look bad as well.
    Photo Sharing and Video Hosting at Photobucket
    So, what was the solution to this?
    I made a filter in FCP (oversaturate and darken) that will be applied to the Final video (in a new Sequence). This is kind of a work around I found, but it’s not accurate. You could also use QT Pro’s Filter, which are clunky and not very helpful.
    Are any of these workflows useful? or am I doing something wrong?
    Rafael Amador replied 19 years, 1 month ago 2 Members · 3 Replies
  • Rafael Amador
    August 4, 2007 at 5:03 am
    Did you set the QT player in “High quality”?
    rafael
  • Matt Capocci
    August 5, 2007 at 6:27 pm
    Yes, I set that when I first installed QT Pro. For some strange reason, it’s off by default? That’s silly, it should always be on…
    I often thought it might be the player as well… There is a difference if I open a RAW clip in FCP vs QT Player. Maybe QT just sucks and that’s why it’s free or $30 for Pro (or however much it is).
  • Rafael Amador
    August 6, 2007 at 3:21 am
    HI Kaypatch,
    Although you got in the QT prefferences “Use High-quality setting when available” this doesn’t work.
    You must open the movie, them Com-J> Video Track>Visual Setting> High Quality.
    Them you can save the set for that movie.
    Cheers,
    rafael
