Activity Forums Adobe After Effects Exploding frame?
  • Exploding frame?
    Posted by Adam Taylor on October 15, 2007 at 1:22 pm
    Whats the easiest/quickest way to have an entire frame of video appear to explode into dust/stars/sparkly tinselly stuff?
    Is ther a simple plug in that can do this, or is it all a big job with particle generators etc?
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
    Mike Clasby replied 18 years, 11 months ago 3 Members · 2 Replies
  • David Bogie
    October 15, 2007 at 2:03 pm
    Shatter.
    It’s in the manual and in the effects pdf.
    It’s easy unless you think you want to try to control it.
    bogiesan
  • Mike Clasby
    October 15, 2007 at 6:52 pm
    You might also check out Simulate>CC Ball Action (CC Filter a separate install off the disk), animate the scatter fro 0 to say 150 over a few frames, grid at 1 ball size 75, tweak to taste.
    Then chase that with Scatter or CC Scatterize.
    Very quick. But Shatter is the closed to an explosion.
