Activity › Forums › Adobe After Effects › Expired license error AE CS3
Posted by Rick De boer on December 3, 2007 at 7:31 amHello,
I just bought Adobe After Effects a few weeks ago, and it was doing a great job.
Until yesterday, when everytime I tried to start AE CS3, it came with an error about an expired license.https://img211.imageshack.us/img211/1517/licenseerrorqf3.png
I have tried to install it again, but it doesn’t seem to work.
Does anyone know how this could happen, and how i can solve this?
RickChandan Samanta replied 16 years, 5 months ago 6 Members · 7 Replies -
Rick De boer
December 4, 2007 at 1:39 pmWhen I installed AE3 for the first time I did activate it.
The other times, after re-installing I couldn’t activate because the whole program didn’t start and i only got the error you can see in my first post.Could there be another cause, because I really want to use it again!
Thanks, Rick -
Curious Turtle
December 4, 2007 at 2:37 pmI don’t know if this will help from Adobe’s website.
If that doesn’t work, it’s probably worth giving Adobe support a ring, and let us know what they have to say.
Good luck,
BenCurious Turtle Professional Video
Training | Editing |Support -
Stevytee
December 4, 2007 at 8:53 pmHi Rick, in reply to your post re: license expiry of After Effects, that really shouldn’t have happened if you have a genuine and registered copy. I don’t have any immediate long term solutions, but the same thing happened to a friend of mine. This is what he did: In order to carry on using it until you find a better solution, simply turn your system clock back to early November 2007 {via Control Panel}, you should find that After Effects will start up as normal. Good luck.
Rick De boer
December 6, 2007 at 3:23 pmThank you so much Ben!!
I followed the instructions on the adobe site, and my after effects works fine again!!Thanks!
Rick -
Jake Davi
December 9, 2007 at 1:57 amYes, set your date on your computer to 1 year ago. ( 2006 )
Works!
Chandan Samanta
April 3, 2010 at 2:08 amHello,
Rick
