Activity Forums Storage & Archiving Expansion Slot Utility says my Atto H680 is not working at full speed
  • Expansion Slot Utility says my Atto H680 is not working at full speed
    Posted by Enrique Londaits on May 1, 2015 at 5:22 pm
    Hi eveybody. I just installed an ATTO H680 in my 2009 MacPro, which I intend to use with an external LTO 6 drive.
    As soon as I rebooted I got a message that said my recently installed card was not working at full speed,
    and the Expansion Slot Utility came up. Should I change this configuration or just let it be? Thanks in advance
    Enrique Londaits
    Enrique Londaits replied 11 years, 4 months ago 3 Members · 3 Replies
  • Martin Greenwood
    May 1, 2015 at 6:32 pm
    Hi Enrique,
    I think it’s in slot 2 which is a x1 slot and both your x4 slots have x1 cards installed.
    So I would swap slot 2 with the card in slot 3 or slot 4.
    Best,
    Martin
    CTO
    YoYotta
  • Tim Jones
    May 1, 2015 at 6:37 pm
    Martin’s correct – swap the cards in slots 2 and 4 and then select Profile 1. This is the way that our 1,1 test units are configured. Quadro 4800 in slot 1, Sonnet PCIe Qio card in slot 2, USB 3 card in slot 3 and ATTO H680 or R680 in slot 4.
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.tolisgroup.com
    BRU … because it’s the RESTORE that matters!
  • Enrique Londaits
    May 1, 2015 at 7:53 pm
    Thank you guys. That did it! Best to you
