  • Posted by Sebastien Allain on July 17, 2007 at 1:29 pm
    I’m using such expression to read some value:
    target=comp(thisComp.layer(1).name).layer(thisComp.name);
    I need to automatically target nothing or something else when the target is not available for a moment (no existence)
    (in order not to have an error like this: “impossible to find…”)
    I don’t want to switch on/off each time all this expression.
    it may be something with if(…) has…
    Help please !
    sebastien
    Dan Ebberts replied 19 years, 2 months ago 2 Members · 4 Replies
  • Dan Ebberts
    July 17, 2007 at 1:46 pm
    You can use JavaScript’s try/catch construct for this, like this:
    try{
    }catch(err){
    target = // something else
    In the catch section you have to define what value to use for target if the try section fails.
    Dan
  • Sebastien Allain
    July 17, 2007 at 3:37 pm
    Thanks Dan ! G
  • Sebastien Allain
    July 17, 2007 at 4:37 pm
    Now i need to read the reel scale of a parented layer.
    I don’t understand yet the difference between World and Comp but i remember Dan your expression:
    L = comp(“target”).layer(“target”);
    P = L.toComp(L.L.anchorPoint);
    so i’ve tried with no luck
    L = comp(“3×1”).layer(“LIGNES”);
    P = L.toComp(L.transform.scale);
    Can ask you one more time ?
    sebastien
  • Dan Ebberts
    July 17, 2007 at 5:11 pm
    Try this:
    if (L.hasParent){
    s1 = L.parent.transform.scale;
    s2 = L.transform.scale;
    [s1[0]*s2[0]/100, s1[1]*s2[1]/100]
    }else{
    L.transform.scale
    Dan
