Activity Forums Adobe Premiere Pro Excessive Motion Pixelation Posting Blu-ray?
  • Excessive Motion Pixelation Posting Blu-ray?
    Posted by Jeff Hall on March 9, 2009 at 9:26 pm
    I two am struggling with excessive motion pixelation artifacts??
    Here are my steps………….
    1) Capture using Matrox RTX2 Hardware using Matrox AVI codec
    Type: Matrox AVI
    Image Size: 1440 x 1080i
    Pixel Depth: 24
    Frame Rate: 29.97
    Average Data Rate: 3.2 MB / second
    Pixel Aspect Ratio: 1.3333
    Codec Type: MPEG-2 IBP
    Bit Depth: 8
    Scan Mode: Interlaced – Upper Field First
    Actual Image Size: 1440 x 1080
    2) Encode Matrox AVI using Adobe Media Encoder CS4 Ver. 4.0.2.002
    Set for MPEG2 Blu-ray
    High Quality 1440 x 1080i 29.97fps
    MainConcept Mpeg Quality 5 Codec
    VBR 2 Pass
    Bitrates
    Min 18
    Target 25
    Max 40
    GOP
    M Frames 3
    N Frames 12
    Before importing into Encore CS4 you can observe excessive pixelation.
    3)Import into Encore CS4 to post on Blu-ray
    Rename MPEG to MPG so that Blu-ray transcode status and settings says “Do Not Transcode”. A trick I learned from Matrox forum.
    I want it to look as close to HDV quality original as possible but have been unsuccessful.
    Does anyone have suggestions to address this?
    Thanks so much!
    Jeff Hall replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
