Activity › Forums › VEGAS Pro › Exception 0xC0000005
  • Exception 0xC0000005
    Posted by Paul Perrotta on January 30, 2011 at 7:42 pm
    I keep getting the “Exception 0xC0000005” error below whenever I highlight a section of the movie to play. sometime right before I get the error, some of the movie segments turn completely red.
    Sony Vegas Movie Studio 8.0
    Version 8.0c (Build 142)
    Exception 0xC0000005 (access violation) READ:0x24 IP:0x6A178E
    In Module 'VegasMovieStudio80.exe' at Address 0x400000 + 0x2A178E
    Thread: VideoRender ID=0xF60 Stack=0x9E3F000-0x9E40000
    Registers:
    EAX=67376118 CS=001b EIP=006a178e EFLGS=00010202
    EBX=03080840 SS=0023 ESP=09e3fccc EBP=00000000
    ECX=00000000 DS=0023 ESI=09a2f4d8 FS=003b
    EDX=0553dbc8 ES=0023 EDI=001bdb00 GS=0000
    Bytes at CS:EIP:
    006A178E: 8B 41 24 FF D0 85 C0 74 .A: 0B 83 C5 01 3B 6C 24 10 ....;l
    Stack Dump:
    09E3FCCC: 67376118 66D40000 + 636118
    09E3FCD0: 0553DBC8 05240000 + 2FDBC8
    09E3FCD4: 0553DBC8 05240000 + 2FDBC8
    09E3FCD8: 693FD6DC 690E0000 + 31D6DC
    09E3FCDC: 021BB710 021A0000 + 1B710
    09E3FCE0: 0968A950 09230000 + 45A950
    09E3FCE4: 00000003
    09E3FCE8: 00000006
    09E3FCEC: 00000002
    09E3FCF0: 00000000
    09E3FCF4: 001BDB0C 00140000 + 7DB0C
    09E3FCF8: 0069E6FB 00400000 + 29E6FB (VegasMovieStudio80.exe)
    09E3FCFC: 0553DBC8 05240000 + 2FDBC8
    09E3FD00: 00000000
    09E3FD04: 6733AB28 66D40000 + 5FAB28
    09E3FD08: 021BB710 021A0000 + 1B710
    > 09E3FD0C: 0069F260 00400000 + 29F260 (VegasMovieStudio80.exe)
    09E3FD10: 0968A950 09230000 + 45A950
    09E3FD14: 693FD6DC 690E0000 + 31D6DC
    09E3FD18: 6733AB28 66D40000 + 5FAB28
    09E3FD1C: 00000000
    > 09E3FD30: 006B9E5A 00400000 + 2B9E5A (VegasMovieStudio80.exe)
    09E3FD34: 0968A950 09230000 + 45A950
    09E3FD38: 693FD6DC 690E0000 + 31D6DC
    09E3FD3C: FFFFFFFF
    09E3FD40: 6733AB08 66D40000 + 5FAB08
    > 09E3FD54: 006BA18B 00400000 + 2BA18B (VegasMovieStudio80.exe)
    09E3FD58: 00000000
    > 09E3FD5C: 006BA217 00400000 + 2BA217 (VegasMovieStudio80.exe)
    09E3FD60: 09A2F078 09230000 + 7FF078
    09E3FD64: 6733AAF8 66D40000 + 5FAAF8
    > 09E3FD68: 006BA310 00400000 + 2BA310 (VegasMovieStudio80.exe)
    09E3FFF0: 00000000
    09E3FFF4: 00592990 00400000 + 192990 (VegasMovieStudio80.exe)
    09E3FFF8: 05634140 05240000 + 3F4140
    09E3FFFC: 00000000
    Paul
    Stephen Mann replied 15 years, 8 months ago 3 Members · 2 Replies
  • Aleksey Tarasov
    January 30, 2011 at 8:06 pm
  • Stephen Mann
    January 31, 2011 at 2:45 am
    Everything after “access violation” is of value only to the original programmer, and then only in controlled conditions.
    We have all seen access violations occur since we took ownership of our first x86 PC’s. The infamous “Bluescreen”, application crashes, it doesn’t really matter, access violations are all over the place. For any of you that remember the good old Windows 9x days, a General Protection Fault and Invalid Page Fault are basically the same thing (and a segmentation fault too). To many people, the phrase ‘access violation’ is synonymous with “crash”. But what exactly is an access violation?
    To put it simply, an access violation occurs any time an area of memory is accessed that the program doesn’t have permission to access. This can be due to bad code, faulty RAM or even a bad device driver. It really doesn’t matter who the culprit is, the root issue is the same.
    The free program: Prime95, available at https://files.extremeoverclocking.com/file.php?f=103 will torture test your PC. If you have bad RAM or a heat sensitive component, this program will find it. While you may not be overclocking, Vegas is very processor intensive – more than Premiere. If you have a PC on the edge of stability, Prime95 will push your PC hard. If you can run Prime95 for an hour, then your PC is probably not the problem.
    If you have a problem driver, I recommend running Driver Detective from https://www.drivershq.com/ (Actually a good plan is to run Driver Detective periodically. I doesn’t do anything to your installed drivers unless you tell it to.)
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
