Activity › Forums › Apple Final Cut Pro Legacy › Exact same images – some are blue/green and some are orange – mystery?
  • Exact same images – some are blue/green and some are orange – mystery?
    Posted by Elijah Lynn on August 9, 2010 at 5:12 pm
    I have attached a screenshot of my timeline, these images were exported from Powerpoint as an image sequence. I am going through the sequence, laying them down and as soon as I hit slide/image #41 I started getting the “unlimited” render status. This slows down my preview bigtime as I am throwing opacity on the slides and playing back at 2x speed, when the status is the green/acqua color (vs. blue) the audio plays smooth but when it is orange it is virtually inaudible. This is a XDCAM EX 24p 35mbps sequence.
    Any ideas? Maybe something simple I am overlooking, this has happened with all the previous timelines too.
    964_fcpimagesequencerenderstatusissuewithpowerpointjpgs.png.zip
    Rafael Amador replied 16 years, 1 month ago 2 Members · 3 Replies
  • Rafael Amador
    August 9, 2010 at 5:25 pm
    Hi Elijah,
    Try rising the “Stills Cache”.
    BTW, why are you editing in an XDCAM sequence?
    Even if you are delivering in that format, you will work much better in a prores sequence.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Elijah Lynn
    August 9, 2010 at 5:51 pm
    You da man Rafael!!
    As far as the XDCAM vs. Prores sequence goes, no reason just inexperience! I thought that it would render faster this way, mainly. I will play around with it.
    Cheers,
    Elijah
  • Rafael Amador
    August 9, 2010 at 6:02 pm
    Hi Elijah,
    XDCAM is one of the slower rendering options available.
    If you are delivering in XDCAM, is better to export to a good Intraframe codec (Prores or Uncompress) and re-encode the final master to XDCAM.
    Don’t forget to set “Render in High Precision”.
    Cheers,
    rafael
