Activity › Forums › Apple Final Cut Pro Legacy › exact 60 second audio clip
Posted by Logan Nevitt on February 8, 2010 at 12:23 amHow do I make an exact 60 second audio clip? I either get 59;29 or 1:00;02.
Logan Nevitt replied 16 years, 7 months ago 3 Members · 5 Replies -
David Battistella
February 8, 2010 at 4:37 amYou need to change to NON DROP FRAME TIMECODE.
THis is easily achieved by changing the SEMI COLON ; to a COLON :
The clip ending at 59;29 is actaully more accurate to “clock” time because drop frame TIme code was invented to emulate “exact” clock time. NON DROP results in clips being longer than clock time.
David
Peace
Logan Nevitt
February 8, 2010 at 6:43 amwhich window should I change it in? It reverts back to semicolon when I enter it.
John Fishback
February 9, 2010 at 5:04 pmIf you want accurate timings, keep your timeline in Drop Frame. You can change it in Sequence menu > Timeline Options tab > Check for Drop Frame, not Uncheck for Non-Drop Frame.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
