Activity Forums Apple Final Cut Pro Legacy EX3 workflow ?
  • Andy Mees
    February 23, 2012 at 8:16 am
    Hello Vineet
    You can use the Sony XDCAM EX Log and Transfer plugin to let you import your XDCAM EX footage directly from within FCP’s Log and Transfer interface.
    Or you can use either their XDCAM Transfer or XDCAM Browser application to log, select and transfer/ingest the camera footage to your media drive (this will place the selected footage as Quicktime Movie clips at your chosen import location) after which you can import those clips into your FCP project manually, or have it imported directly to the project as part of the transfer.
    Hope it helps
    Andy
