Activity › Forums › Sony Cameras › EX3 rec button malfunction (plus some shoots)
  • EX3 rec button malfunction (plus some shoots)
    Posted by Enrique Orozco on July 13, 2009 at 4:16 pm
    … very happy with the EX3, however suddenly my main rec button began to fail…. as if it were “moved” or “broken” inside the rubber cover…. I’m preparing to send the camera for service but want to share the experience with other users that maybe have had similar problems …. any comment would be welcome….
    …some EX3 shoots from my town:
    https://www.youtube.com/watch?v=ZmD0kLX6Epk
    kind regards
    Enrique Orozco R.
    iDEA DigitalVideoStudio
    Enrique Orozco replied 17 years, 2 months ago 3 Members · 4 Replies
  • Michael Palmer
    July 13, 2009 at 4:29 pm
    I had the rubber cap become jammed and had to loosen the grip and I was able to reset it. If I remember correctly it rotated and it is definitely something you can fix.
    Good Luck
    Michael Palmer
  • Enrique Orozco
    July 13, 2009 at 5:26 pm
    Thank you Michael …. Do you “open” the grip, or just manipulate the rubber cover ?? … I tried to “take off” the rubber cover in order to find and “fix” the button, but it was very difficult or “risky” …is that easy ??
    kind regards
    Enrique Orozco R.
  • Michael Palmer
    July 13, 2009 at 5:55 pm
    I think I opened the grip and reset the button. It wasn’t hard to do so if you are careful it should save you the time lost of taking it in for service.
    Good Luck
    Michael Palmer
  • Enrique Orozco
    July 13, 2009 at 6:26 pm
    Thank you… I’ll check your suggestion …
    Regards
    Enrique Orozco R.
