Activity › Forums › Sony Cameras › EX3, Prime Lenses and 35mm adaptors
Posted by Joe Murray on July 18, 2008 at 3:16 pmHas anyone had any experience of the Sony EX3 and prime (cine’ or stills) lenses.
Do the focal lengths stay the same? On my Canon XL1 35mm still lenses were multiplied by 7x – making it a fairly pointless exercise.
What about adaptors like the Redrock or Letus, is there any point in using one?
Has anyone tested them out>
Thanks.Antoine Petit replied 15 years, 6 months ago 8 Members · 17 Replies -
Don Greening
July 18, 2008 at 5:00 pm[Joe Murray] “Has anyone tested them out> “
You might want to email Phil Bloom in the U.K. He’s done a lot of work using the lens adapters you’ve mentioned and was also one of the first to do an in-depth review of the EX3. He owns several HD lenses and would be the one to ask for a recommendation.
Phil’s an extremely busy guy these days but if he has the time he’ll certainly try to answer your questions and he also has a message board on his web site.
https://www.philipbloom.co.uk/Philip_Bloom/Home.html
– Don
Ron Shook
July 18, 2008 at 5:53 pmDon,
[Don Greening] “You might want to email Phil Bloom in the U.K.”
I did ask Philip that exact question about 6 months ago, so I can answer to Joe. With a 35mm adapter like the Letus you will obtain roughly the same field of view as with a 35mm still camera. It might even be a touch wider. So, for instance, if you had a Letus adapter with a 35mm Nikor lens on it, you would see about the same field of view on an EX as you would with the standard lens zoomed to nearly full wide, but with considerably less depth of field.
Ron Shook
Shoulder-High Eye Productions
CreativeCOW Forum Host for Discreet edit* -
Denis O’keefe
July 18, 2008 at 6:15 pmThe EX 1 is essentially the same as the EX 3, except for the removable lens and ergonomic improvements- and is reported to be pretty nice. Because it has the removable lens there are relay lenses being made to connect the Letus to the EX 3, instead of connecting to the attached lens on the EX 1.
Using an adapter to put a 35mm lens onto the camera as you suggest changes the focal length and not much else.
Using the Letus (or another brand) moves the focal plane to a groundglass ( that is vibrating or spinning ), leaving you with the desirable properties of the 35 mm lens – shallow depth of field, sharp focus where you want it, nice out of focus areas where you want that.
If you search on http://www.exposureroom.com for letus and ex 1 you’ll see how good it can look. -
Steve
July 24, 2008 at 10:27 amMy experience with adapters has been with the EX1 to date, the Letus Extreme and now with the Letus Ultimate. Check out the blog
https://web.mac.com/stevecahill/Steve_Cahills_Blog/Blog/Blog.htmlAlso specifc videos with the new letus Ultimate @
https://exposureroom.com/members/stevecahill.aspx/assets/33d2b44c5fcb4c3ebcadf62d527d0b86/&
https://exposureroom.com/members/stevecahill.aspx/assets/c256f8e50a7b4644a6d3a6168bf93457/
Regards
SteveBlog: https://web.mac.com/stevecahill/Steve_Cahills_Blog/Blog/Blog.html
Joe Murray
July 24, 2008 at 12:19 pmGreat stuff, nice pics and a good blog.
Very informative.
I suppose what I’d really like is to dispose of a “twin lens system”
ie get an adaptor that will alow me to mount lenses straight onto the EX3, while
retaining the depth of field characteristics if the prime/35mm lens.Dual 1.25 MD, FCP 4.02, CW4, 1.25GB RAM, DUAL ATTO, Medea RT480 QT6.3
Carelton Holt
July 24, 2008 at 1:25 pmYou might check with Dennis Wood at Cinevate.com as well. We are shooting with the EX1 using both the Letus Extreme and the Brevis 35 with very nice results. If the EX3 sales are robust, there is probably a good chance that Cinevate would produce a relay lens for the Brevis. This would not completely eliminate the “twin lens” issue, but might help with some of the vignetting and edge focus that comes from mounting any of the ground glass adapters onto the stock lens of your camera. In any event, the image quality from the EX1 is good enough that we can often eliminate either of these problems by enlarging the image about 3 to 5 percent and cropping out most all of the frame edge problems.
Steve
July 24, 2008 at 11:36 pmWait for the relay lens to come out then you will not have to deal with a “twin Lens” though it allows for additional zooming if you need it.
Regards
Joe Murray
July 25, 2008 at 7:48 amAt the risk of sounding dim.
What is the relay lens?Dual 1.25 MD, FCP 4.02, CW4, 1.25GB RAM, DUAL ATTO, Medea RT480 QT6.3
Michael Palmer
July 25, 2008 at 2:29 pm“What is the relay lens?”
I believe It is a lens that can allow the camera to see the image on the spinning optical plain.
Good Luck
Michael Palmer -
Don Greening
July 25, 2008 at 5:29 pmIn the purest sense of the definition, a relay race is the act of passing the baton from one team member to another. With lenses a relay lens is the passing of the image from one lens to another lens, more specifically when you want to invert or extend the image.
– Don
