Activity Forums Sony Cameras EX3 Fujinon lens problem
  • EX3 Fujinon lens problem
    Posted by Sveinung Bokn on June 12, 2010 at 11:24 pm
    When I turn the camera on a strange sound from the lens is heard, its like there is no comunication between the lens and the body. The camera will not focus, in the display the aperture indicates c and does not change the number when I change it manually. the zoom goes back and forth at random number electronically not mechanically (z number changes randomly). When I change the zoom manually it does not respond to this with the z number. I demounted the lens, put it back on, it appeared a strange vignetting in the upper left corner. I reseted the camera. Did not help. Is the lens broken? Or is it a humidity problem/contact problem? Its still under warranty time…
    kindest regards..
    sveinung bokn
    Sveinung Bokn
    Sveinung Bokn replied 15 years, 11 months ago 3 Members · 3 Replies
  • Michael Palmer
    June 13, 2010 at 3:53 pm
    It sounds like you need to return this to Sony, something have come loose inside.
    Good Luck
    Michael Palmer
  • Ronnie Martin
    June 14, 2010 at 8:47 pm
    If you have another camera that you could try the lens on that would eliminate either the camera or the lens…. Maybe put the stock lens back on the camera and see if it behaves properly.
    sorry for your problems good luck
    Ronnie
    https://www.ramtv.tv
    Ronnie Martin
    Kato Video Productions
    http://www.dirtracingvideo.com
  • Sveinung Bokn
    June 14, 2010 at 11:08 pm
    I tried another cameras lense (same one) on my camera (body) and it worked fine, and then I tried my seems to be broken lense on the other camera and the same problem appeared. So I guess its the lens. I have sent it to the store where I bought it. Its still under warranty. So I hope they will fix /replace it.
    thank you..
    sveinung
    Sveinung Bokn
