Activity › Forums › Sony Cameras › EX3 clips are way onger on time line
  • EX3 clips are way onger on time line
    Posted by Tushar Patel on August 20, 2012 at 1:54 am
    I imported the EX3 clips from copied card on my hard drive. the length of the clips is 1 hour and 36 min ( all clips are part of one clip captured on ex3) on time line it shows total of 12 plus hours. any suggestions?
    Bala Chandran replied 14 years, 1 month ago 4 Members · 4 Replies
  • Michael Palmer
    August 20, 2012 at 2:32 pm
    What NLE are you using?
    You said you captured these clips, capturing is when you use the camera as a deck and connect it to a capture software that re-encodes the video signal to a new digital codec. If this is what you did this could be your issue.
    If you transferred the clips from the camera in their native state you need to look at your sequence setting from your NLE
    Good Luck
    Michael Palmer
  • Bala Chandran
    August 20, 2012 at 10:14 pm
    When you dragged them to the timeline there must have been some repeats, if your recording was non-stop for long duration. Delete duplicates from the timeline and you will end up with the correct length.
  • Don Greening
    August 20, 2012 at 10:19 pm
    [Bala Chandran] “When you dragged them to the timeline there must have been some repeats,”
    In FCP 7 that happens a lot, actually. You just have to be vigilant as to the length of what you’re dropping in and delete any repeats.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Bala Chandran
    August 21, 2012 at 11:09 pm
    Same deal in PPro too when you drag and drop to the timeline! I guess the problem stems from the way EX breaks up the shoot every 3.38 gigs.
