Activity Forums Apple Final Cut Pro Legacy EX1 XDCam Footage in FCP 6.0
  • EX1 XDCam Footage in FCP 6.0
    Posted by Jared Smith on March 31, 2009 at 3:08 am
    Hey guys,
    I have not made the purchase yet of the EX1, but I am trying to cover all the bases. If I buy this camera will I have any trouble using FCP 6.0 with the XDCAM footage?
    jared
    Jeremy Garchow replied 17 years, 4 months ago 7 Members · 7 Replies
  • 7 Replies
  • Jerry Hofmann
    March 31, 2009 at 3:42 am
    I just finished a project shot with that camera and didn’t have any problems with FCP per se…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Alex Elkins
    March 31, 2009 at 2:27 pm
    It works fine with FCP. You do need a couple of free plugins from Sony though. It’s also worth noting that due to the long-GOP nature of XDCAM I always render to ProRes or ProRes HQ for final render and output.
    I read an article about a JVC camera that is being released around NAB time that records to the XDCAM format, but the files are automatically wrapped for use in FCP. This means that ingesting is literally a case of drag and dropping from the card into your scratch disk. No re-wrapping as you have to do with the Sony XDCAM files. Might be worth looking into as I think it’s about the same price as the EX1, maybe a bit more but it has detachable lenses too, which is a huge plus for a lot of people. It’s called the JVC GY-HM700.
  • Chris Borjis
    March 31, 2009 at 4:21 pm
    well one thing to be sure is that you are running at least 6.03
    or later.
    earlier versions are not supported or have issues.
  • Jeremy Garchow
    March 31, 2009 at 4:38 pm
    I just finished my first XDCam project no too long ago, and man it is weird. Be prepared for a lot of waiting and rendering.
    Jeremy
  • Andrew Kimery
    March 31, 2009 at 5:59 pm
    What are the specs of the computer(s) you’ll be using? XDCAM EX is a more CPU intensive codec than DVCPro HD, for example, so an older machine that runs DVCPro HD fine will struggle a bit more w/XDCAM EX. W/that being said, we’ve been using an EX1 for nearly a year now on shorter projects (less than 10 minutes) on Mac Pros as well as G5s and have no real complaints.
    -A
    3.2GHz 8-core, FCP 6.0.4, 10.5.5
    Blackmagic Multibridge Eclipse (6.8.1)
  • Mario Rubertis
    May 2, 2009 at 10:34 pm
    Jeremy,
    I’ve been working with XDCAM EX natively on the timeline with my Matrox MXO2 with NO rendering on my 8core MacPro.
    Maybe I can help you figure out what you’ve been doing wrong.
    It works flawlessly for me.
    I bring in my footage, put it on my timeline, edit and while I’m editing I see it on my HMDI monitor as smooth as silk. I can play XDCAM EX straight off my timeline using my Matrox MXO2.
    Stay well.
    An Artist At Heart.
    Life is made of moments…
  • Jeremy Garchow
    May 2, 2009 at 11:47 pm
    The new AJA io Express is codec independent and can work with XDCam native.
    I don’t work with XDCam that much and prefer AJA products.
