Activity Forums Sony Cameras EX1 & Sennheiser 416 microphone
  • EX1 & Sennheiser 416 microphone
    Posted by Nik Read on May 10, 2009 at 7:23 pm
    Hi all, Just wondered if anyone has any advice about general audio settings for the EX1 when using a 416…? I’ve tried a few, with various results but am keen to know what you guys think. WWith my old DVCAM cameras you could just plug the 416 in, leave the audio channels on auto most of the time and audio was always great, but with the EX1 it seems to need more adjustment. What are the best audio settings generally for this camera? I’m still new to it so any help would be very much appreciated.
    all the best, Nik
    Michael Palmer replied 17 years, 4 months ago 4 Members · 3 Replies
  • David C jones
    May 11, 2009 at 4:15 am
    Hi Nik-
    The 416, as you know, is a very sensitive mic, and since you’re not running it through a mixer first, I would leave the camera set to “auto”. The factory trim setting for mic level is -41dB; this may be fine but I would do some testing with it first. Check for any over modulation issues and adjust accordingly.
    Regards,
    Dave J
  • Steve Wargo
    May 11, 2009 at 4:20 am
    Set your audio to -59db. Professional mics are mostly -60db. And, you’ll probably have to turn the phantom power on.
    So, the switch under the mic connector is set at the far right position and the impedance is set to -59db.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
    Sony HDCAM F-900 & HDW-2000/1 deck
    5 Final Cut (not quite PRO) systems
    Sony HVR-M25 HDV deck
    2-Sony EX-1 HD .
  • Michael Palmer
    May 11, 2009 at 2:26 pm
    I like my OLD 415 mic. I use it together with a PSC 48PH – 12T converter and it sounds great.
    Good Luck
    Michael Palmer
