Activity › Forums › Sony Cameras › EX1 SDI 1080 output always interlaced?
  • EX1 SDI 1080 output always interlaced?
    Posted by Navarro Parker on January 7, 2010 at 7:58 pm
    I have my EX1 set to 1080P/24. When it records to the SxS cards, the resulting Quicktimes say they are 24p. And visually, they are not interlaced.
    However, using a new Decklink SDI (which supports 1080/24P & 24PfS), I’m unable to see video.
    So have you heard any problems if the EX1 outputs true 1080p via SDI? I can only get an interlaced SDI output when in 1080p mode.
    At first, I thought 1080p would be too much for a single link SDI connect. But at 4:2:2 1080/24p, it squeaks under the threshold for single link SDI.
    Maurice Jansen replied 16 years, 8 months ago 3 Members · 2 Replies
  • Alister Chapman
    January 10, 2010 at 6:44 pm
    The output is PsF (Progressive Segmented Frame). It appears as an interlace signal, but within the interlace signal you have progressive frames. This is normal for 1080P OVER HDSDI
    Alister Chapman
    http://www.xdcam-user.com
  • Maurice Jansen
    January 10, 2010 at 9:45 pm
    hi
    look at page 105 of your EX1 manual
    it tell’s you how to change the HD-SDI output from 60I to 24PsF.
    maybe it will help
    grt
    Maurice
    People saying they don’t make mistake’s often make nothing at all!
