Activity Forums Apple Final Cut Pro Legacy EX1 media capture problem
  • EX1 media capture problem
    Posted by Javad Ahmadi on June 13, 2008 at 7:34 pm
    Hello Everyone!
    I have difficulties capturing EX1 content with FinalCut.
    My FCP version is 6.0.3. I installed XDCam EX clip browser, but I can not get it under my import menu inside FC. My OS version is 10.4.11.
    Another issue is that I used a Firewire cable to connect Sony EX1 into my G5 and it does not mount on my desktop? I checked on the EX1 menu, the iLink option can not be selected.
    Please advise, what I am doing wrong.
    thank you in advance
    Javad
    Javad Ahmadi replied 18 years, 3 months ago 2 Members · 4 Replies
  • Don Greening
    June 13, 2008 at 7:50 pm
    [Javad Ahmadi] “My FCP version is 6.0.3. I installed XDCam EX clip browser, but I can not get it under my import menu inside FC.”
    Sony’s Clip Browser software is not used for transfer to FCP. You have to use the Sony Transfer Tool for this purpose.
    [Javad Ahmadi] “Another issue is that I used a Firewire cable to connect Sony EX1 into my G5 and it does not mount on my desktop?”
    The EX1 does not use the firewire port to transfer files. The EX1’s USB connection is what’s used if you intend on using the camera to transfer files from the SxS Pro memory card to your computer.
    The above information is all in your EX1 owner’s manual.
    – Don
  • Javad Ahmadi
    June 13, 2008 at 8:12 pm
    Don, thanks for your feedback.
    I had to return the camera. I will get the USB reader card to capture the footage. Now, the XDCam software handles the reader the same as the Camera and I start capturing?
    I filmed at 720i (1280×720). A particular setting I should change in the preference. Please advise.
    A quick note will help me a lot.
    thanks
  • Don Greening
    June 13, 2008 at 8:38 pm
    [Javad Ahmadi] “Now, the XDCam software handles the reader the same as the Camera and I start capturing?”
    The USB reader should work the same as if you had an EX hooked up via USB. You do need to install the Sony FAM driver on to your Mac otherwise the reader (or camera for that matter) will not show up on your desktop. The FAM driver is available at the Sony web site as a free download as well as on the software installation CD that ships with the camera. The FAM driver will enable the USB reader or camera to mount on the desktop and is used like any other attached device like an external hard drive etc.
    [Javad Ahmadi] “I filmed at 720i (1280×720). A particular setting I should change in the preference. Please advise.”
    Each clip on the card has attached information about the recording mode and that data is read by the Sony Transfer Tool which in turn tranfers the data to FCP. Once your card is mounted and seen by both programs just choose the proper sequence setting in your “Easy Setups” menu withn FCP.
    – Don
  • Javad Ahmadi
    June 13, 2008 at 9:08 pm
    Many Thanks Don. I will try it tomorrow and let see what happens.
    Javad
