Activity › Forums › Sony Cameras › EX1 Audio config
  • EX1 Audio config
    Posted by Richard Rodriguez on March 2, 2009 at 5:35 pm
    Hello,
    For the EX1, where do you set the tone reference…-20 or 0(like for BETA-SP).
    What is happening is when we bring the files into FCP with HD setting, the audio is extremely low.
    By the same token, we don’t want it over modulated.
    Thank you in advance for your help.
    Rich
    Richard Rodriguez
    David C jones replied 17 years, 6 months ago 3 Members · 2 Replies
  • Don Greening
    March 2, 2009 at 11:11 pm
    Hi Richard,
    The EX will output an audio reference signal along with the colour bars but you have to turn it on first. Go to the Audio Set menu and turn on the “1kHz Tone” function. Then go back and press the “Bars/Cam” button under the handle. Now you should be outputting bars and tone. When you’re done don’t forget to go back to the Audio Set menu and turn the tone output off.
    – Don
  • David C jones
    March 3, 2009 at 4:40 am
    Hi Richard-
    Yes, you want the reference tone at -20. Your audio should peak around there as well. But monitor, monitor, MONITOR! Use headphones or at least an earpiece. Just because the levels look good, doesn’t mean you’re not getting distorted audio.
    Regards,
    Dave J
