Activity Forums Adobe After Effects EX-HD Footage from Premiere to After Effects: Black Frames
  • EX-HD Footage from Premiere to After Effects: Black Frames
    Posted by Shahir Daud on June 4, 2008 at 3:42 am
    Hi there
    I’m currently editing some XDCAM EX1 (HQ1080 50i) footage in Premiere, then shipping the premiere project into After Effects to do some compositing and motion graphics work.
    At present, when I import the project into After Effects, the sequence will occasionaly play with a few black frames interspersed throughout the footage. If I render out the sequence without any after effects work on it (ie. masking, position moves etc), then it renders out without any of those black frames.
    However, whenever I do any sort of work in After Effects, the black frames become permanant, and will appear in my render.
    My render settings are Uncompressed Quicktime – usually I am downscaling the HD Video to an SD Composition and moving around the HD frame.
    Has anyone else had any problems with XDCAM (MP4) footage in After Effects.
    The current work around seems to be importing the footage into After Effects, render it out untouched into a quicktime uncompressed file, then re-import it back into after effects to work on it – this is quite a tasking work around, and not necessarily the best way.
    I have upgraded all my software to the latest versions.
    Please help!
    shahir.daud@gmail.com
    Ron Coy replied 18 years, 3 months ago 2 Members · 1 Reply
  • Ron Coy
    June 5, 2008 at 2:54 pm
    If you’re using non-temporal footage (like mpg, h.264 and possibly the MP4 footage you speak of), this will cause all kinds of weirdness in After Effects, as it doesn’t contain complete video frame data. These codecs throw away information that AE needs to work properly.
    If you’re lucky enough to be able to convert it using After Effects to a codec/format that contains all video frame data necessary for AE to use, which it seems like that’s the case from your post, then you already have your solution.
    Many people have to convert the footage before they can even use it in AE to output any files at all.
