Activity Forums Sony Cameras EX-1 Camera Zoom used in tandem w/ 35mm Adapter?
  • EX-1 Camera Zoom used in tandem w/ 35mm Adapter?
    Posted by Emile Wamsteker on October 21, 2009 at 10:26 pm
    When I mount my 35mm adapter to the front element of my EX-1 lens, I need to calibrate focus first, and then adjust the CAMERA’s zoom so that the image fills the frame. If I don’t adjust the Camera’s zoom, I run the risk of vignetting.
    My question is, once I’ve found the sweet spot and mark the zoom barrel, can I zoom in further if I wish–in effect using the camera’s zoom as a tele-extender–and if so, to what extent. Will I have image degradation if I do? Or should I just leave it on the sweet spot, and treat it as a fixed focal length lens.
    For example, when I have a 50mm prime mounted on the adapter, the EX-1’s zoom is set to about 40mm to fill the frame. If the zoom is set wider, I get vignetting. Zoom tighter–to say 80m–and I am in effect changing the mounted lens’ focal length, making it longer. I wonder if there is perceptible image degradation.
    I am new to video, so judging whether or not there is degradation, is not easy for my eye to see but I wonder what others think and have observed.
    Thanks in advance for your help.
    Cheers,
    -Emile
    Emile Wamsteker replied 16 years, 10 months ago 3 Members · 3 Replies
  • Bob Pierce
    October 22, 2009 at 11:16 am
    Yes. I do it all the time with my Letus, and have never noticed any degradation. Sometimes shooting interviews I need just a bit of flexibility with zooming (with a prime mounted). I wouldn’t push it too much, though. Phillip Bloom has written about this and does it himself.
    Bob
    http://www.lightstreamassociates.com
    Mac Pro 2.66 – 8GB memory –
    Mac Book Pro 2.33 Duo –
    FC Studio 2 – Kona Lhe
    Adobe Production Suite CS4 –
    Sony Multiformat 14″ – Panasonic 42″ Plasma –
    Ikegami HLDV7 – PVW EX-1
  • Michael Palmer
    October 22, 2009 at 3:12 pm
    Yes Bob is right, you can’t push into the end, or at least I can’t using the Red Rock Encore. The focus on the stock lens needs adjustment and I tape off the focus ring on the stock lens once I find the sweet spot.
    I can count on Z73 to keep all of my Nikon lenses from vignetting and a few I can widen out a little more.
    One thing to keep in mind is that a 28mm has a definitive look and feel and by zooming in on the stock lens it doesn’t change and make it feel like a 35mm, it basically crops the field of view. I prefer to lock the stock lens at Z73 and change lenses to find the right composition.
    Good Luck
    Michael Palmer
  • Emile Wamsteker
    October 28, 2009 at 1:22 pm
    Thanks Bob, and Michael,
    This confirms what I thought, but needed reassurance from seasoned pros like you.
    I’ve since run tests, and to my untrained video eye, I see no loss in quality when zooming into the subject using the EX-1 onboard zoom.
    Thanks again for your comments.
    Cheers,
    -Emile
