Activity › Forums › Adobe After Effects › Every few minutes composition motitor goes black
Posted by Kandiimann Shane on August 20, 2013 at 11:23 pmHi =) My issue is that every few minutes my composition monitor goes black and i have to restart after effects to get it back to normal. This is happening every 10 to 20 minutes. Do u guys have any idea how i might be able to fix this? thank you =)
Kandiimann Shane replied 13 years ago 3 Members · 14 Replies -
Todd Kopriva
August 21, 2013 at 5:58 amWe need to know a lot more if we’re going to help you. Please provide answers to the questions listed here
After Effects team blog
Kandiimann Shane
August 21, 2013 at 7:22 pmhi, thank you for your response, i’m running CS6, i have installed the latest updates, this is the laptop its on https://www.toshibadirect.com/td/b2c/cdetland.to?poid=2000098991 .. the only difference is i have 8 gigs ram.. the other specs are the same,
■Intel® Core™ i7-4700MQ quad core processor
■Windows 8
■8GB DDR3L memory
■500GB (5400RPM) hard drive
■NVIDIA® GeForce® GT 740M with Optimus™
■1920×1080 TruBrite displayquick time is installed
multi processing is on
do you need any more information? -
Ericbowen
August 21, 2013 at 8:25 pm -
Kandiimann Shane
August 22, 2013 at 12:02 amthanks so much for your response.. i just tried that but im not sure it helped.. i tested AE by playing with an effects-heavy project and after about 7 minutes it went black but only at 100% zoom.. if i zoomed in or out it went back to normal but if i went back to 100% it was black..
could it be my multiprocessing settings? right now its on 8 installed CPUs, 1 reserved for other applications, ram allocation per background cpu: 3 gb..
Ericbowen
August 22, 2013 at 2:19 pmChange the ram assignment per core to 1GB. What Nvidia driver are you running? Right click on the Desktop and select the Nvidia Control panel. Then select help at the top and select system information. Please list the Nvidia driver.
Eric-ADK
Tech Manager -
Ericbowen
August 22, 2013 at 10:38 pmDownload this driver:
https://www.geforce.com/drivers/results/63462
Select Custom install when it prompts. Check Mark Clean install and uncheck the Nvidia Experience and Framework if listed.
Eric-ADK
Tech Manager -
Kandiimann Shane
August 22, 2013 at 11:08 pmWOW ok actually im pretty sure the problem was my multiprocessing settings.. i changed it to 1 gb per cpu and i think that solved the problem! =D should i still download that driver? would it make AE faster?
Ericbowen
August 23, 2013 at 2:19 pmI would suggest the new driver. Just make sure to install as listed before.
Eric-ADK
Tech Manager -
Kandiimann Shane
August 25, 2013 at 9:14 pmhi EricBowen, i installed the new driver and i unchecked experience, i did not see framework but i left physx checked, was this the correct procedure?
