Activity Forums VEGAS Pro event pan/crop disappears!
  • event pan/crop disappears!
    Posted by Ron Mentson on July 12, 2009 at 12:07 am
    i have sony vegas pro 8 and everytime i click the event pan crop on anything (video/audio) the pop up drops down somewhere and disappears.it was working,but now it doesnt.its weird cause event fx works fine.i cant find any settings to make it pop up and stay on my screen.what should i do to fix it?thanks
    Mike Fields replied 17 years, 2 months ago 4 Members · 3 Replies
  • Steve Rhoden
    July 12, 2009 at 4:18 am
    you have several options i could suggest, but first:
    Go to view then to window layouts then
    click default layout.
    Or you can autohide the taskbar, and then drag up the
    vegas event/pan crop window when the taskbar
    drops out of view.
    Steve Rhoden
    (Cow Leader)
    Creative Arts Director and Film Maker.
    Project Samples at:
    http://www.youtube.com/hentys
  • John Rofrano
    July 12, 2009 at 12:37 pm
    And if none of Steve’s suggestions work, you can hold down Ctrl+Shift while starting Vegas and it will reset all of your preferences to the way they were when Vegas was first installed. Warning: you will loose any changes to the preferences that you have made so only use this as a last resort.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Mike Fields
    July 12, 2009 at 3:30 pm
    Do you by chance have a second monitor that is not turned on ?? I have had this happen before where I had moved a window over to the second monitor and forgot I had done that. The application thoughtfully remembered where I left it and put it back there again … even though the monitor was not turned on 🙂
    mikey
    You can’t have too much disk space or too many gadgets !!
