Activity › Forums › VEGAS Pro › Event grouping gone after Excalibur “extract good clips”?
  • Event grouping gone after Excalibur “extract good clips”?
    Posted by Dan Sherman on August 21, 2005 at 5:55 pm
    After using Excalibur “extract good clips” function, audio is no longer linked to video and vice versa. As though “ignore event grouping” is activated. But it isn’t. Is there an easier work around than selecting both audio and video. Also when “select events to the end” is selected,—only the video, or audio, is chosen.
    Edward Troxel replied 21 years, 1 month ago 2 Members · 1 Reply
  • Edward Troxel
    August 21, 2005 at 6:21 pm
    Yes, that is an unfortunate side effect. Here’s a possible workaround for you:
    1) Run Extract Good Clips ONLY on the video.
    2) Select all the extracted Video clips
    3) Run “Restore Missing A/V” on the Repair/Maint tab.
    Edward Troxel
    JETDV Scripts
