Activity › Forums › VEGAS Pro › Event FX won't show up Sony Vegas 17pro
  • Event FX won't show up Sony Vegas 17pro
    Posted by Maciek Kuliński on August 6, 2021 at 12:47 pm
    Hello
    Like in title when i click on it nothing really happened. I tried youtube tutorials how to fix this but its not working. Probably when i was holding the window it go somewhere and now i don’t know how to have it again. Please tell me step by step what to do im losing hours of job and feel sad ;/ look at the picture maybe this will make u more understand my trouble ..
    Edward Troxel replied 5 years, 1 month ago 3 Members · 2 Replies
  • Francois Pénzes
    August 8, 2021 at 4:46 pm
    Hi Maciek
    First, Please stop calling it Sony Vegas. Sony SOLD Vegas to Magix. The last version they made was Vegas 13 and that was 5 years ago.
    Now on to your question. There is a menu in each of the tracks at the far left, click left once on the 3 little lines. A menu will appear. Click on Edit Visible Button Set… and then choose Track FX.
    In my opinion, it is much better to use Track FX instead of Event FX. When you choose the Track FX, it will add it to ALL clips added on that track. When editing, I found that adding clips on separate tracks makes it easier to work on tweaking each one to your liking. It also helps a lot if you name each of your tracks. This way, you can find everything faster. You may be able to remember where everything is in the moment, but if you have to stop for a couple of days and return to it, you may not remember where everything was and which track was what.
    Cheers !
  • Edward Troxel
    August 9, 2021 at 2:35 pm
    It sounds like the effects window may be hidden under the Windows start bar. You might try changing to a higher resolution or setting to start bar to auto hide and see if you can find it there.
    And there is no such thing as the product you mentioned. You are using VEGAS Pro 17 by Magix.
