Activity Forums VEGAS Pro Event FX and the preview screen
  • Event FX and the preview screen
    Posted by Harrell Williams on August 31, 2008 at 6:27 pm
    I’ve added an Event FX (black & white) to my track. In the preview screen, my choices to preview are:
    FX Bypassed (can’t be de-selected)
    Clip Board
    Select Left Half (shows FX on left half of preview footage)
    Select Right Half (shows FX on right half of…)
    Select All (preview stays the same)
    The “Left/Right” selects are the only 2 that work, whereas I can see the FX I choose on the preview screen. Will what I’m seeing be spread over the “whole” footage after I save/render the footage?
    Thanks.
    Harrell Williams replied 18 years ago 3 Members · 3 Replies
  • Terry Esslinger
    August 31, 2008 at 7:13 pm
    Yes, the preview views are only to allow you to see the difference between the affected and unaffected footage. The Fx will be applied to the entire event.
  • Edward Troxel
    September 2, 2008 at 12:42 am
    Click on the button to the LEFT of the drop down arrow to turn it OFF.
    Edward Troxel
    JETDV Scripts
  • Harrell Williams
    September 2, 2008 at 4:13 pm
    I am nearing my final questions…
    I have edited the footage.
    That which was shot with Night Shot, and was re-baked (by the professional using Final Cut Pro) is now in “black & white.”
    But I used some other footage, like digital photos, exterior footage, all which I want to keep as it’s “regular color.”
    When I am previewing the “whole” version of my edited works, in the preview section/screen, if I select “Red to Grayscale” it turns “all” of what is previewed into “black & white” footage (same with “Blue to Grayscale”). Not a problem (I’m just not sure what the outcome will be once rendered).
    For the footage I want to stay as “regular color”, I put it on a separate track, separate from the footage that is “black & white”, and footage that has the Night Shot/green tint (I separated it all out on separate tracks so I could apply a “track FX, or event FX” where needed, so the effects would not cross each other in any way (meaning, mainly the track FX).
    Questions:
    When I preview the whole edited version, that which is supposed to be color footage is also black & white. I guess if I have the “preview” feature set to “Red to Grayscale”, it will show the “whole” edited version in “black & white”, not just what I choose to be “B&W”; is that correct? Meaning, when I render it, the color will be color and black & white, black & white (as I’ve selected it to be)?
    I’m thinking I’m going to have to spend time rendering, then playing the footage on an Architect DVD a few times in order to see which effects took, if the color footage came out as selected; same for the black & white. There might not be an answer to my issue, but just in case… Thank you. I’ve learned a huge lesson here.
