Activity Forums Adobe After Effects Expressions escaping windows backslashes
  • escaping windows backslashes
    Posted by Peter O’connell on October 2, 2008 at 2:34 pm
    Hi I am using the layer object “applyPreset” method which requires a file path as the argument. When I use a window file path that has backslashes I either have to double up all the backslashes or change them all to forward slashes before it will work. Is there a way to have the javascript interpret the backslashes correctly. I was hoping “escape()” would work but no dice it seems.
    Pete
    Peter O’connell replied 17 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
