Activity Forums Apple Final Cut Pro Legacy eSata card and 10.5.5
  • eSata card and 10.5.5
    Posted by Ryan Atkins on October 18, 2008 at 3:47 am
    I just bought a Rosewill Expresscard 34 device for my macbook pro and is hooked into a 7200 rpm 500 GB external, this is going to be used for editing. Well, I installed the driver for this card and was trying to transfer about 40 GB worth of data over to it. It was transfering in “spurts” and took about an hour to transfer the data over. There are lights on my card and they only blinked for about a few seconds at a time, meanwhile the status bar crept slowly across my screen.
    I’ve read that the driver that comes with the RC-605 (Sil132_1.1.9u_Sil) may not be compatible with Leopard 10.5.5
    Any ideas?
    Zane Barker replied 17 years, 10 months ago 5 Members · 13 Replies
  • 13 Replies
  • David Roth weiss
    October 18, 2008 at 3:53 am
    Get your express card from Firmtek. There are many expres cards on the market, but only a few that work reliably on a Macbook/Macbook Pro. https://firmtek.stores.yahoo.net/seritek2sm2e.html
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Zane Barker
    October 18, 2008 at 6:34 am
    [Ryan Atkins] “Sil132”
    Yea that driver is JANKY.
    And I just looked into the package contents of the firmtek card and it contains the same problematic Sil132 driver.
    I know people that have had no problems using it, I on the other hand have had nothing but problems with it. It seems to pick and choose which model MBP it will play nice with.
    There are no “technical solutions” to your “artistic problems”.
    Don’t let technology get in the way of your creativity!
  • Ryan Atkins
    October 19, 2008 at 4:50 am
    Is there such a card manufactured that runs perfect on any version of Leopard? I read that the RC-605 runs great on 10.5.1 and has a driver included on a CD as well as Rosewills website.
    I was getting very inconsistent data transfers and ended up resulting back to my firewire connection, which transferred my 40 GB of data in about 20 minutes. I can live with that, not an hour…
    Any suggestions for eSata, other than the Firmtek?
    Unlike Windows operating systems, Mac OS X seems to update their software much more frequently, so I can see why the driver wouldn’t work…but I’m not going to downgrade to 10.5.1 just to use the eSata cards.
  • Ryan Atkins
    October 19, 2008 at 8:18 pm
    David,
    Going off of what Zane mentioned about the Sil132 driver, is the Firmtek compatible with the latest version of Leopard 10.5.5? Really, this card would be no better than the Rosewill RC-605 if it has not worked with these latest updates. I don’t know if any other users have updated their Macs running Leopard to 10.5.5.
    Knowing the 10.5.5 update is relatively new, you’d think that there are cards whos drivers are compatible with this…
  • Sean Oneil
    October 19, 2008 at 9:01 pm
    Ryan. Firmtek has a driver update for their product on the website. You might want to try it with your product since it has the same SATA controller.
    Sean
  • Ryan Atkins
    October 19, 2008 at 9:10 pm
    Thank you for the info. I will try this and hope that I get better results…
    Ryan
  • Ryan Atkins
    October 19, 2008 at 9:14 pm
    Forgot to ask this in my last post.
    There are many drivers, for I assume their product line. Could I just pick one or is there a specific card whos driver is the same as mine?
  • Ryan Atkins
    October 19, 2008 at 9:31 pm
    Thanks Sean, I had much better results. I tried out an 11 GB transfer, which was only going to take about 10 minutes. However, the transfer stopped a few times. I’ve already contacted Rosewill support about the inconsistency in general, but I may decide that I can deal with the transfers stopping randomly, not sure.
    It’s sure not functioning like a transfer between internal SATA hard drives.
  • Sean Oneil
    October 19, 2008 at 9:35 pm
    Which product is the same as yours? Use that one.
    The driver update could be a replacement for the Apple driver, which could make it work or make it not work at all. You’d have to remove it and re-install the original Apple driver (which is complicated).
    There’s also a firmware update. Chances are it won’t work with your product. But it could – which could in turn fix your problem, or ruin the card completely. Just giving you fair warning here.
    Sean
  • Tom Matthies
    October 20, 2008 at 6:00 pm
    I needed to do a firmware update on my Firmtek ESATA enclosure to get it to work on my Mac Pro running Leopard. After the update, it’s been solid as a rock. Check with support at Firmtek for info.
    Tom
