Activity › Forums › Avid Media Composer › errors when capturing with firewire drives
  • errors when capturing with firewire drives
    Posted by Lee on September 25, 2006 at 4:04 pm
    using Media composer software
    Mojo SDI
    QUAD 2.5
    1 gig of ram
    Lacie firewire drives
    I am getting errors when caputuring 1:1 from digital betcam
    Capture aborted due to video overrun. The media captured at this point may be unuseable and/or incomplete
    anyone seen this issue
    Paul
    “FOR GODS SAKE I’VE READ THE MANUAL”
    Lee replied 20 years ago 4 Members · 4 Replies
  • Bouke Vahl
    September 25, 2006 at 4:37 pm
    Did you read the part about drive speed and datarate of uncompressed video?
    Wild guess.
    Your drive is too slow.
    Since you can afford a digibeta, you also can afford a decent array 🙂
    Bouke
  • Scott Simmons
    September 25, 2006 at 4:57 pm
    If you have to use Firewire drives check out G-Technology, G-RAID drives.
    Life is linear. Edit life.
  • Michael Hancock
    September 25, 2006 at 5:48 pm
    In addition to slow drives, I’m pretty sure the minimum requirements for Media Composer ask for 2 Gig of RAM, even better if you go to 3. Plus, and I’m not really familiar with Macs, but if your Mojo is sharing the same bus as your firewire you’ll have a lot of problems–the Mojo doesn’t like to share resources, so you may need a seperate firewire card (you do on a PC, it might be different on a Mac), and if you do need a firewire card it likely has to go into a specific slot.
    Mike.
  • Lee
    September 26, 2006 at 11:13 am
    thanks mike very useful
