Activity › Forums › Adobe After Effects › Error’s Everywhere!
  • Error’s Everywhere!
    Posted by Henry on July 25, 2005 at 7:38 am
    Everytime I try to render out my movie, regardless what it is, I get all sorts of different errors, sometimes it will work. Sometimes it wont.
    After Effects error: could not create 720 x 576 image buffer.
    : Not enough memory to render 13.5 seconds of audio.
    I am on a G5 with 2GB of memory. I never got these problems before 3d Invigorator.
    Whats the best settings for RAM output etc…?
    Dan replied 21 years, 1 month ago 4 Members · 4 Replies
  • John Dickinson
    July 25, 2005 at 7:48 am
    Are you using the latest version of 3D Invigorator?
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Henry
    July 25, 2005 at 8:02 am
    Yes – well last Friday’s!
    It get’s about 3/4 of the way through a full animation, then stops.
    I try different codecs but to no avail.
    It does work if I export it tho, as opposed to render out.
  • Filip Vandueren
    July 25, 2005 at 1:46 pm
    hold down shift when you go into the preferences to get to the ‘secret’ prefs
    You can set an automatic RAM-purge every X frames during rendering there.
    Hopefully that helps.
  • Dan
    August 5, 2005 at 4:08 pm
    It’s shift-ctrl in windows.
