Activity › Forums › Adobe After Effects › ERROR/GLITCH in AE 6.5, help!!!
Posted by Noizzz on December 27, 2006 at 3:47 pmHello,
i’am having a strange error here, and I can
Jack Hilkewich replied 19 years, 8 months ago 2 Members · 3 Replies -
Jack Hilkewich
December 27, 2006 at 4:26 pmI’ll start this by asking the obvious questions. Have you checked the position of the lights? The intensity? Are they pointed in the proper direction? Is there some type of layer in the way? Look for the easiest answers first, you may have inadvertently moved the position of some thing or other. I find that usually it’s something like that.
What happens if you add an ambient light to the mix and crank the intensity way up?
Noizzz
December 27, 2006 at 5:23 pmThanx for the advice, but it was a bit more technical. I actually found the problem. I had set the color dept at 16bit, and the pc didn
Jack Hilkewich
December 27, 2006 at 6:31 pmmmmm, That’s strange as any project that I make in 16 bit depth seems to work with lights. Maybe it is the files that you have imported. Have you tried a text layer to see if it shows up?
