Activity Forums Adobe After Effects Expressions error with color epxression
  • error with color epxression
    Posted by Assaf Goldlust on March 3, 2018 at 7:08 pm
    in the book “AE Expressions”
    he gave the following expression
    var red=thisComp.layer("Controls").effect("Red")("Slider");
    var green=thisComp.layer("Controls").effect("Green")("Slider");
    var blue=thisComp.layer("Controls").effect("Blue")("Slider");
    var alpha=1;
    var hsl=
    rgbToHsl=([red,green,blue,alpha])
    hsl[0]+=.5;
    if (hsl[0]>1)hsl[0][H11546]=1;
    var rgb = hslToRgb(hsl);
    rgb
    but keep getting an error that tells me that
    H11546 in class 'global' is missing or dosent exist
    I have compared what i wrote against whats in the book and i dont see why,
    can any of your help me out here?
    Dan Ebberts replied 8 years, 5 months ago 2 Members · 12 Replies
  • 12 Replies
  • Dan Ebberts
    March 3, 2018 at 8:12 pm
    I think it should be like this:
    var red=thisComp.layer(“Controls”).effect(“Red”)(“Slider”);
    var green=thisComp.layer(“Controls”).effect(“Green”)(“Slider”);
    var blue=thisComp.layer(“Controls”).effect(“Blue”)(“Slider”);
    var alpha=1;
    var hsl = rgbToHsl([red,green,blue,alpha]);
    hsl[0]+=.5;
    if (hsl[0]>1)hsl[0] -= 1;
    rgb
    Dan
  • Assaf Goldlust
    March 3, 2018 at 8:19 pm
    wait, so why in the book its looks like this?
  • Dan Ebberts
    March 3, 2018 at 8:27 pm
    It definitely does not look like that in my copy. Maybe you have a newer edition, where it somehow got messed up.
    Dan
  • Assaf Goldlust
    March 4, 2018 at 5:58 am
    Well,this sucks
  • Assaf Goldlust
    March 4, 2018 at 10:40 am
    Any way, i have another queation.
    At some point in the expression he used the code
    hsl[0] + = .5;
    And later he explained:
    “+ = .5” means add .5 to whatever the value already is.
    Im slightly confused,
    What is tge diffrence bewtween the usual
    Value=+.5?
  • Dan Ebberts
    March 4, 2018 at 4:39 pm
    It would be:
    hsl[0] += .5;
    (no space between the + and the = ).
    += is a JavaScript shorthand operator that gives you the same result as:
    hsl[0] = hsl[0] + .5;
    Dan
  • Assaf Goldlust
    March 5, 2018 at 5:46 am
    So if i lets say want to do:
    T=transform.position[0]+5;
    I can instead do?
    transform.position[0]+=5;
  • Dan Ebberts
    March 5, 2018 at 7:54 am
    The first one takes the layer’s x postion, adds 5 to it, and stuffs the result in variable T.
    I don’t think the second one actually does anything (except maybe generate an error). So no, they’re not equivalent.
    Dan
  • Assaf Goldlust
    March 7, 2018 at 4:57 pm
    so whats is this operator function?
    i mean in general not just in the contest of this color expression?
  • Dan Ebberts
    March 7, 2018 at 5:09 pm
    += is one of JavaScript’s assignment operators.
    Where
    x += y
    is the same as
    x = x + y
    Dan
