Activity Forums Adobe Encore DVD Error when trying to burn DVD with CS3 using scc files
  • Error when trying to burn DVD with CS3 using scc files
    Posted by Mk Kearney on August 10, 2009 at 4:07 pm
    So what ever happened? I’m having a problem with the scc file also. Burns just fine when the scc file isn’t inserted. When the scc file is inserted I can’t get the build to go past, ” Preparing Disk Layout”.
    Mark Kearney
    Currently, I am working in Adobe Encore CS 3. The only time I had this issue is when I insert a scc file for closed captioning, otherwise the disk burns fine.
    When the scc file is inserted and I start the build for the burn, a “Parameters is Invalid” message appears and my disk fails to burned.
    The captioning copy has made a modification on the time code form 00:00:00:00 to 00:00:00:02. It still doesn’t work.
    I have searched many forums and while I have read several of them the only solution I have seen if for the time code change mentioned above.
    Does anybody have a better solution? As stated the disk burns just fine when the scc file is not inserted.
    Thanks.
    Jason Livingston replied 17 years ago 2 Members · 1 Reply
  • Jason Livingston
    August 15, 2009 at 12:58 am
    Encore will fail with SCC files that have any captions within the first two seconds (00:00:02:00).
    It looks like maybe your caption company was on the right track, but they fixed only the first two frames (00:02) instead of two seconds (02:00).
    Jason Livingston
    CPC
