Activity › Forums › Apple Final Cut Pro Legacy › error to loading fill from p2 card
Posted by Alon Grego on May 6, 2009 at 9:24 pmHi to you,
i work with final cut pro 6.0.5 i try to loading from panasonic AG-HPG10 P2HD card rider
most of the file are transfer to my project but some of them make me an error ” 1 clip queued-idle.”
i know that file are transfer into another computer with good result.what i can do to transfer that file?
thanks Alon
Shane Ross replied 17 years, 2 months ago 3 Members · 5 Replies -
Shane Ross
May 6, 2009 at 10:35 pm#36 – One or More P2 files failed to import.
Shane’s Stock Answer #36 – “One or more clips failed to import…”
Very often in the field with this camera the camera operator will delete clips from the P2 card that they just don’t like. That is the beauty of this camera. But, the still for that video file (located in the CLIP folder in the CONTENTS folder)…the still that you see when you are in the P2 Import window…is not deleted. So you will see the image, and the name, but the video file would have been deleted.
What you can do it compare the file names in the VIDEO folder and CLIP folder and see if anything is missing. If something is, then you know what the problem is. You can then just import the rest a few at time, skipping that one.
ALSO…in the P2 Import window…in the P2 Browser, there is a little sprocket drop down menu. Click on that and choose PREFERENCES. Uncheck REMOVE PULLDOWN and then try importing again.
ALSO…make sure your file names aren’t too long. Try shortening them and see if that works.
ALSO make sure that the folders that contain the CONTENTS folder doesn’t have any odd characters like /!@#$%^&*()?.
Shane
Read my blog, Little Frog in High Def -
Alon Grego
May 7, 2009 at 7:39 amHi Dear Shane,
thanks for yours respond,i did what you wrote but nothing happened i still have the same problem.
i know that material from that card transfer in other edit room with the same program.
what is not understand to me is that some of the fill are transfer and some not.
i check out on the preferences windows i make restart to the program.
but still we get the same error.
i try to send to you a scren shot of the problem
thank you
Alon
picture2.png -
Shane Ross
May 7, 2009 at 4:15 pmOK, first off, is this DVCPRO HD P2 or AVCIntra P2?
Second, click on the red exclaimation point and tell me what it says the error is.
Shane
Josh Greenbaum
June 16, 2009 at 3:44 pmI just posted a similar question, perhaps I can pirate this thread. I am having the same problem. When I mouse over the exclamation point it says error:no data. Footage was shot on an HVX in 720 / 24pN. I tried both with the removed pulldown box checked and unchecked. I can preview the entire clip, but it stops transferring toward the end. Any suggestions?
Shane Ross
June 16, 2009 at 4:30 pmThe only ones I have are in my stock answer. Sorry.
Shane
