error render
Posted by Pepita on October 19, 2007 at 6:15 amHello Guys,
IMary Waitrovich replied 18 years, 11 months ago 2 Members · 1 Reply -
1 Reply
Mary Waitrovich
October 22, 2007 at 4:42 pmPepita,
Not sure exactly what your problem is, but recently I encountered something similar where my project could not finish a render without error. I was using a noise reduction plug-in called Neat Video on many of the clips and this turned out to be the culprit. When I went to the Neat website I found out that others had the same problem, and also that there was an update to the plug-in which solved the problem.So I would try rendering without magic bullet and Zenote Glow first. Also visit the website of those plugins to see if there are any updates or suggestions in the support forums.
Good luck,
Mary Waitrovich
UW-Madison
