Activity › Forums › Adobe After Effects › ERROR: opening sound component (-2166) ?
  • ERROR: opening sound component (-2166) ?
    Posted by David Mattock on December 19, 2005 at 10:29 am
    Hi, I am getting the following error in my lateset AE project
    error: opening sound component (-2166).
    (10:44)
    I get this sometimes when I Ram preview but sometimes its ok?, but If I try to render I always get this error and it wont render unless I turn off all my audio layers, … any ideas ?, Ive never had a problem with sound before. they are just wav files
    Thanks in advance
    info@davidmattock.co.uk
    David Mattock replied 20 years, 9 months ago 5,599 Members · 1 Reply
  • David Mattock
    December 20, 2005 at 2:28 pm
    Its OK, After reading through other posts with the same problem I shockingly found out it was because I had the latest version of Quicktime Pro and it was the culprit which made AE 6 Pro error.
    Ive upgraded to 6.5 and this has sorted the problem. If you cant upgrade you need to go back to quicktime 7.01
    cheers
