Activity Forums Adobe After Effects ERROR OPENING SOUND COMPOMENT IN AE6 (-2166)
  • ERROR OPENING SOUND COMPOMENT IN AE6 (-2166)
    Posted by Dan Smith on February 26, 2008 at 6:33 pm
    PLEASE HELP! I NEED TO RENDER THIS FILE! THE IDEO FILE RENDERS FINE BY ITSELF, AS DOES THE AUDIO, WHAT CAN I DO….
    Admin note: Please do not use all caps in your name and subject lines, Dan. Thank you, The COW Team
    Dan Smith replied 18 years, 7 months ago 2 Members · 3 Replies
  • Steve Roberts
    February 26, 2008 at 6:40 pm
    DO YOU HAVE QUICKTIME 7.4? IT IS BAD. TRY 7.4.1.
    ARE YOU USING MP3 FILES? CONVERT THEM TO WAV OR AIFF BEFORE IMPORTING INTO AE.
    Rendering? Minimize AE. No need for Caps Lock.
  • Dan Smith
    February 26, 2008 at 6:44 pm
    I ve 7.4.1 and have had caps lock on will try the minimise, but other than that im a bit stuped!
    Dan Smith
    Bionicmedia
    Art Director
  • Dan Smith
    February 26, 2008 at 7:15 pm
    Cheers that appears to have solved the problem! Thanks!
    Dan Smith
    Bionicmedia
    Art Director
