Activity Forums Boris FX Particle Illusion Error Opening Library: Default.il3
  • Error Opening Library: Default.il3
    Posted by Brad Staupp on January 15, 2008 at 7:41 pm
    After Installing Particle Illusion 3 I am getting an Error Opening Library: Default.il3 when I try to run it. I have uninstaller, re-installed and re-activated with the same results. How can I solve this problem?
    Brad
    Alan Lorence replied 18 years, 7 months ago 2 Members · 1 Reply
  • Alan Lorence
    January 15, 2008 at 8:54 pm
    It’s telling you that it can’t find the file — just browse to the folder where particleIllusion is installed, then the “Emitter Libraries” folder, then select any library file there.
    Alan.
    http://www.wondertouch.com
