Error occurred starting Vegas, system is running low on memory
I’ve tried this on several computers, but keep getting the same error. Installation goes successfully, but when I run the program, I see the splash screen for a few seconds, then an error window that says:
“An error occurred starting Vegas Pro. The system is running low on memory. You may be able to reduce memory usage by closing applications.”
This happens for all versions of Vegas I try to install on my PC. I have Vegas 6 on my laptop and it works fine with all kinds of apps running. I’ve tried expanding the paging file size and disabling terminal services, but still no luck. I have 1GB RAM, and a 2.0Ghz AMD Athlon processor, so I don’t think that should be a problem. Some folks on other forums seem to be having the same issue, but no solutions yet. Any ideas?
Thanks in advance!
