Activity Forums DaVinci Resolve “Error occured communicating with a Digital Powerhouse Decoder”
  • “Error occured communicating with a Digital Powerhouse Decoder”
    Posted by Chad Terpstra on September 29, 2011 at 6:19 pm
    I keep getting this message and it sounds like others here have found a way to fix it. I have the following system:
    2010 2.8GHz Quad-Core Mac Pro w/ 16GB Ram
    GT120
    GTX 470
    BlackMagic Decklink HD Extreme (8.5 software)
    Cuda driver: 4.0.50
    GPU Driver Version 7.4.10
    Resolve 8.0.1
    What can I try to fix this? Thanks!
    Chad Terpstra replied 14 years, 11 months ago 3 Members · 5 Replies
  • Peter Chamberlain
    September 30, 2011 at 1:18 am
    Hi Chad, is this a single or dual quad core?
    It may not relate to the digital powerhouse message but with 2010 MacPro its best to use 6, 12 or 24GB ram based on the way the CPU threading works. Can you try with 12?
    Peter
  • Chad Terpstra
    October 1, 2011 at 1:03 am
    Single quad core. I suppose I could take a stick of Ram out but I don’t think the system likes having unbalanced ram. Any other ideas I could try?
  • Chad Terpstra
    October 6, 2011 at 5:35 pm
    Does anyone have any ideas I could try? I installed Blackmagic Decklink v8.6 and then uninstalled it completely from the system and re-installed Resolve. This made it come out as version 7.9.5. CUDA driver 4.0.50 and GPU driver version 7.4.10 270.05.05f01
    Should I try a different CUDA version or GPU driver? Uninstall it then reinstall Resolve? Any clues would be great because at the moment I can’t render a single full res R3D without errors and black frames. Even half debayer sometimes kills it.
    Any help would be greatly appreciated!
  • Rohit Gupta
    October 6, 2011 at 5:39 pm
    This is a known issue on Lion with 8.0.1. A fix for this will be available in the upcoming 8.1.
  • Chad Terpstra
    October 6, 2011 at 6:26 pm
    So what is everyone doing in the meantime? Not running on Lion? I thought some folks were up and running on Lion without problems.
