Activity › Forums › Adobe After Effects › ERROR need 2 or more frames to playback
  • ERROR need 2 or more frames to playback
    Posted by Gerardo Flores on July 25, 2010 at 9:24 pm
    Hi every body
    did any of you know how to solve this problem?
    may a small .mov footage from digital juice cause the problem
    and if yes??? how I shall convert the footage to work with them?
    estrange situation this never happens before and i was using the same files 🙁
    Regards from Czech Republic.
    learning after effects
    Keith Mcgregor replied 16 years, 2 months ago 3 Members · 2 Replies
  • Tudor “ted” jelescu
    July 26, 2010 at 7:49 am
    I got that message a few times. In CS4 it usually goes away once you assign more memory to RAM preview.
    Tudor “Ted” Jelescu
    Senior Compositor/VFX Artist
    Bucharest, Romania
  • Keith Mcgregor
    July 26, 2010 at 7:30 pm
    Don’t forget to empty the database and cashe folder or purging all under Edit/Purge/All. Helped me more than once.
    -Keith
    Reality? What did you make it?
