Activity Forums Adobe After Effects Error: .MOV Files
  • Error: .MOV Files
    Posted by Jeff Carpenter on August 25, 2009 at 3:20 am
    When I try to import a .mov file, I get an error that says: “Script Alert!” at the top and then “Error: After Effects Error: File ‘Blood.mov’ is not a valid type for import”. I try the file in Quicktime and it works fine. Any ideas?
    Roland R. kahlenberg replied 17 years, 1 month ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    August 25, 2009 at 4:09 am
    Never seen this but it’s likely a CODEC issue. Try exporting out from QT into a CODEC that you normally use within AE.
    Good luck!
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
