Activity › Forums › Adobe After Effects Expressions › error message when using brackets
  • Filip Vandueren
    April 30, 2007 at 4:05 pm
    Havn’t installed CS3 on this machine yet, but could you test this:
    Do you get the same error when you add “.value” at the end of your expression ?
    like this:
    (thisComp.layer(“Black Solid 1”).transform.opacity.value)
  • Peter O’connell
    April 30, 2007 at 6:39 pm
    Hi, the error message still comes up if I type in .value. The expression seems to work if I just click OK and ignore it though.
    Pete O’Connell
    http://www.barxseven.com
