Activity Forums Apple Final Cut Pro Legacy Error message when rendering
  • Error message when rendering
    Posted by Chris Babbitt on December 20, 2006 at 6:31 pm
    Quite often, when I hit the render button, I get an error message that says “File Error – The specified file is open and in use by this or another application.” I then have to close the message and start the render again. This appears to be a bug, since there are no other files or applications open at the time. Has anyone else seen this? I am running 5.1.2 on an Intel MacPro.
    David Bogie replied 19 years, 9 months ago 2 Members · 1 Reply
  • David Bogie
    December 20, 2006 at 7:03 pm
    It’s not a bug: it is inconsistent nor does it appear on many machines.
    You may have the clip selected in a hidden Finder window that is set to show previews. That would tie up the file.
    We’ve also heard of this error coming up when a clip has been exported as a background in LiveType. No clean solution that I have seen, too many unrelated circumstances when we’ve seen it posted but we have seen it in on our systems.
    bogiesan
