Activity › Forums › Apple Final Cut Pro Legacy › Error Message when Importing P2 Footage into FCP
  • Error Message when Importing P2 Footage into FCP
    Posted by Carly Lyn on April 11, 2007 at 9:17 pm
    I’ve tried importing the clips as a group and individually. But I keep getting this error message:
    “One or more P2 clips failed to import; probably incomplete or corrupt clips”
    Is there any hope? What am I doing wrong? What should I do?
    SB
    Shane Ross replied 19 years, 5 months ago 2 Members · 3 Replies
  • Shane Ross
    April 11, 2007 at 9:21 pm
    In the P2 Import window, click on the Sprocket looking thing…you’ll get a drop down menu. Select preferences. Turn off REMOVE DUPLICATE FRAMES.
    Try again.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Carly Lyn
    April 11, 2007 at 9:44 pm
    I have Final Cut Pro 5.0 and don’t see any sprocket thing in the P2 import window. Is there a way I can change preferences some other way?
    SB
  • Shane Ross
    April 11, 2007 at 9:47 pm
    AH…that option is with FCP 5.1. You need at least FCP 5.0.4 to import P2 footage.
    Shane
    Littlefrog Post
    http://www.lfhd.net
