Activity Forums Adobe Premiere Pro error message when burnig to dvd pp1.5
  • error message when burnig to dvd pp1.5
    Posted by Big Juan on October 16, 2007 at 2:49 pm
    Hi There
    First time here so go easy on me
    I have done a project and tried to export it to dvd to burn ..process goes on for several hours (thats ok project lasts about 2hrs ) but the stops with the following message
    ”Could not complete the last command because device error – sense code (44400)-
    Internal target failure – general dvd err, 279552”
    I have tried to burn this three times and change some of the settings ,
    ie
    High quality, low bandwidth VBR transcoding of DV content (max bit rate = 7) or others in the list .I live in the uk so I take it I need to use a pal dv setting not a ntsc dv setting ,
    I have burned dvds before but this time it just wont complete the burn
    please help
    Cheers
    John
    Blast1 replied 18 years, 11 months ago 2 Members · 2 Replies
  • Big Juan
    October 17, 2007 at 12:50 pm
    can anybody help???
  • Blast1
    October 17, 2007 at 6:15 pm
    Your problem could be a bunch of different things, a corrupted source file for one, instead of buring to a disk try buring to a ISO file or to a folder vice a disk and see if you still get a problem of somekind, it will help to pin down the cause, it could be not enough memory or disk cache space, firm ware problems in the burner, burner problems, burn media not so hot, alot of times this happens as some branded media switches suppliers,
    To see what variations for “Internal target failure” there are, do a net search for the same.
