Activity Forums Adobe Encore DVD Error Message when building. Help!
  • Error Message when building. Help!
    Posted by Tony Zaragoza on September 16, 2008 at 4:33 am
    “That menu is corrupt. Please delete it from the project.”
    HUH? I’m using menus from Encore’s library.
    The only thing I see at this time is, under the Menu panel, it shows the Main menu Override as “not set” and the End Action for this menu is “Main manu:Defaut”.
    Is the menu corrupt or does setting and End Action or Override affect anything here? (note: I have one timeline with 5 chapter points, each point has and End Action, set in the chapter properties panel, to return to the main menu after you play the one video, from clicking its button).
    PS: I’m trying to ‘build’ folder, not burn a DVD. My first REAL attempt at using my newly learned Encore skills. UGH!
    PPS: When I try to close Encore CS3 and clik on Save, it give me the SAME error message, so I have to click on ‘no’ to close it!
    Tony Zaragoza replied 18 years ago 1 Member · 0 Replies
  • 0 Replies
