Activity Forums Adobe After Effects error message pop-up in After Effects…
  • error message pop-up in After Effects…
    Posted by Augie Ingratta on March 23, 2008 at 3:47 pm
    Hoping that someone can help me with this problem….
    When I hit the the “0”, (zero), key to do a ram preview in After Effects, I get this error message pop-up……….. “After Effects error: RAM preview needs 2 or more frames to playback”
    My project is 25 secs. long.
    Jim Wilcox replied 18 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • Steve Roberts
    March 23, 2008 at 4:47 pm
    Yeah, this is a goofy error that I’ve only been able to solve by restarting the app.
    The error hasn’t occurred with the CS3 version, though.
    Anybody else?
  • Jonathan Shohet
    March 23, 2008 at 7:20 pm
    make sure your maximum RAM cache size is not set below 60%, in your preferences -> memory & cache
  • Darby Edelen
    March 23, 2008 at 10:17 pm
    [jonathan shohet] “make sure your maximum RAM cache size is not set below 60%, in your preferences -> memory & cache”
    Is this a documented issue? Because I’ve set mine below 60% to avoid render issues in the past.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Augie Ingratta
    March 24, 2008 at 12:39 pm
    O.K…….got the RAM preview to work in After Effects CS3.
    “Max Ram Cache size” in the preferences menu was set to 10%…..changed the value to 85% and it does a Ram preview when I hit the “0” key.
    Thanks for the help.
  • Darby Edelen
    March 24, 2008 at 4:44 pm
    [Augie Ingratta] “changed the value to 85% and it does a Ram preview when I hit the “0” key. “
    85% is a little high, I would recommend 60% to avoid render errors.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Augie Ingratta
    March 24, 2008 at 6:09 pm
    Thanks for the suggestion………will drop the value to 60%
  • Jim Wilcox
    March 24, 2008 at 6:42 pm
    You might also check to make sure your work area selected isn’t less than 2 frames. If you accidently hit “b” and ‘n’ together it will set your in and out points of your work area to the same frame and then you would be asking AE to preview a 1 frame comp.
