Activity Forums Avid Media Composer error message on XDCAM import
  • error message on XDCAM import
    Posted by Aldo Palumbo on September 29, 2011 at 3:40 pm
    Hello
    Can any one help with this problem importing?
    I’m using Avid Media Composer 5.5. The project is XDCAM. The footage was shot on the Panasonic AF101 recording to a Nanoflash in the MXF format, and brought to me on a drive. Hundreds of clips of imported successfully, but not this one.
    When I drag the camera file (.mxf) to the bin, the import begins; video and Audio files are created on the media drive, before an error message says:
    Exception: XDCAMHiresAudioimportReader::LocateSamples – Sample miscalculation
    No clip appears in the bin.
    I have used Media Tool to identify the media on the media drive, and then dragged the Media Tool clip to the bin. The clip appears in the bin, but on attempting to open, gives this error message:
    MPEGMapper CalcTemporalOffset Did not find first temporal sample
    An error message early in my attempts suggested a conflict regarding number frames (4082 not 4104).
    I have tried modifying, consolidating and transcoding, and have also deleted the AMA log files, as suggested on the Avid Knowledge Base.
    Any help would be much appreciated.
    many thanks
    Aldo Palumbo
    Aldo Palumbo
    http://www.aldopalumbo.com
    Aldo Palumbo replied 14 years, 8 months ago 4 Members · 6 Replies
  • Jonathan Seaborn
    October 19, 2011 at 6:43 pm
    same error did you find a workaround?
  • Aldo Palumbo
    October 20, 2011 at 7:09 am
    Well, I got it working somehow. It imported following a succession of attempts. Unfortunately I can’t remember precisely the steps, but the important thing was that there were specific frames that had been causing the problem, and depending on where I placed the position indicator in the Source monitor, it would either play or produce an error message. Once at that precarious stage, I marked and In and an Out early in the clip, and then nudged the Out along until I found the trouble spot. I then brought the Out back from the trouble spot, and exported the marked portion with native settings to produce a fully reliable replacement file.
    I hope that helps.
    Aldo Palumbo
  • Michael Riskin
    December 4, 2011 at 6:41 am
    I’m getting this error in 6.0
    Just trying to consolidate and move some files off my drives to a back up drive. I selected “delete original” and “skip media…. Already on drive”
    Any thoughts? Thanks!
  • Aldo Palumbo
    December 4, 2011 at 11:55 am
    Give it a go as per my previous message.
    But I would deselect ‘delete original’ and ‘skip media’.
    good luck
    Aldo
    Aldo Palumbo
  • Mike Jeffs
    December 21, 2011 at 4:45 pm
    I’m doing some tests with MC 6 and i’m getting this error when i try and import a clip recorded from a Omneon Spectrum. One of the clips have tied importing didn’t even have audio associated with the it. stil the same error.
    Mike Jeffs
    Video Coordinator
    BYU-Idaho
  • Aldo Palumbo
    December 22, 2011 at 9:28 am
    Hi Mike
    I’m not so familiar with MC6 or the Omneon, so all I can advise is to persevere or try to find some other software that might allow you to load, mark and export a sub clip to as an independent, functional file.
    all the best
    Aldo
    Aldo Palumbo
