Activity Forums Adobe Premiere Pro Error message on start-up — should I worry?
  • Error message on start-up — should I worry?
    Posted by Bob Cole on August 1, 2005 at 7:28 pm
    I have a new HP 8200xw, and am using it for Premiere Pro.
    Every third or so start-up, PPro won’t load, and I get the following message:
    ASL Message Window: Adobe PremierePro.exe Application Error
    The instruction at “0x0a9ac91” referenced memory at “0x00000000”. The memory could not be “written”. Click on OK to terminate the program.
    Is this something that other PPro users have seen, or is there something wrong with my new, under-warranty computer?
    — BC
    Coolondigi replied 21 years, 1 month ago 3 Members · 3 Replies
  • Steven L. gotz
    August 1, 2005 at 7:49 pm
    Sounds like a problem with your hardware. Have you tested your memory?
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Bob Cole
    August 2, 2005 at 3:56 am
    [Steven L. Gotz] “Have you tested your memory?”
    No. What do you recommend for testing. PPro is the only program which has shown a problem, though.
    — Bob
  • Coolondigi
    August 2, 2005 at 4:23 am
    https://www.memtest.org/ – Give this a try.
